Can you Bolt in OFNA .21?
665_Almost_Evil
Someone said that they put OFNA .21 in without a conversion! Can this be done? I didnt think it could but I may do that instead of the Megatech .16
There is no way to bolt a 21 onto a T-Maxx without making some kind of modification or buying some kind of mod/conversion kit.
if 3maxxman is around, he did it, but it doesn't just "bolt in" requires lots of modifications.
Sig Looks good Kellen. Wouldn't you need a longer chassis so that there is enough room for the crankcase ???Or could you just do some moving around and squeeze it in there ??
No one said it couldn't be done...
What was said was:
That was the question.
originally posted by 665 Almost Evil
Someone said that they put OFNA .21 in without a conversion! Can this be done?...
3maxxman made it work by an ingenious use of smarts and other MT parts.
I totally agree with you Sky. I was just saying that it can be done without a conversion kit. It does require some serious modification though. I assumed he was referring to a conversion kit, which was the only way I thought it could be done until 3maxxman showed that it could be done on a standard chassis.
CORRECTION: The only way a .21 will fit on a T maxx is by way of commercially available conversion kits or serious modifications via an ingenious use of smarts and other monster truck parts.
