Yea ,if it is not that old ,it should be under warranty if you had not modified nothing or used too high of
a cell count!
Either way that you go ,it will take time ,so if you did get it at your local H.S. ,I think maybe you should take
it down there an have them test the stuff ,an they maybe able to diagnose & fix it on the spot were you dont
have to wait too long ,but ,I wouldn't recommend running it like that ,or even have a batt. plugged to it ,if it is a servo
shorting out ,it could fry something else!
I was thinking back ,an remembered ,that I do have a servo that does that same very thing ,an I still have it!
Sense that I run nitro ,I was using it for my throttle ,it was doing like yours causing my engine to rev hi an low ,
also it was twitching ,so yes ,a servo will do that behavior ,especially a steering servo that takes a lot of hard hits
& punishment!
