yep definitely stock up on those e-clips, it would be smart to stock up on the more breakable parts, namely the a-arms when you can and hub carriers, both front and rear, but primarily front. i am in a few FB groups that i have been able to acquire some of the parts but also available on ebay with some searching.
for the front at least if you can, id prioritize RPM a-arms if you can find them.
use a bit of blue loctite on things that go into metal, do not use it on screws going into plastic though. it is a good idea to go through and double check screws before runs.
do keep in mind, the RC10gt uses SAE hardware, the AE .15 itself will be metric, but the rest of the rig will be SAE, i highly recommend getting a good high quality machined driver, at least for the 1/16, as it is a really small hole that likes to strip easy with the cheaper ones and the "L" wrenches. on a budget the Dynamite Machined hex driver has worked great for me for over a year.
another thing you want to keep up on especially with the rc10gt is the diff, make sure to maintain it periodically, you can still get parts easily as most of the wear components are the same as current models (i.e. diff rings and balls). for inside the diff make sure to use ball diff lube, my preference is AEs own stealth lube. you can't use grease as it is not grease/lube in a way that is supposed to completely negate friction as the diff needs friction to actuate. for the small thrust bearing in the outdrive you can use a wider variety, but i still prefer the losi or AE black high pressure grease. they are semi expensive, but you dont use a lot of it and just one package goes a long way and you know its the right stuff to get the most out of your diffs.
