They say it brushless ready as far as trans with metal gears and bearings. I would get a bearing kit for the whole truck. Not sure about the axles thoughHey gang wots occurring,I'm looking at traxxas bigfoot,convert it to brushless,go faster,wud I just need to change motor and esc or other things thx
Or cud I get a stampede, just stick a bigfoot body on itJust start with the motor and ESC and then replace things as they break with upgraded versions but yeah you'll probably have to replace some other things too. CVDs probably for sure.
Yes, that's probably the easier option.Or cud I get a stampede, just stick a bigfoot body on it
If you want vxl system, or for no headaches, yes. If you want abother brushless system, buy the xl5 and upgrade.Or cud I get a stampede, just stick a bigfoot body on it
Yes I would get the 4x4 vxl stampede. The bigfoot is only 2wd. Then you can pick what ever body you want on it. The bigfoot is built off the two wheel drive stampede chassis and set up just some little differences.Or cud I get a stampede, just stick a bigfoot body on it
Yeah, I also vote for buying the 4WD Pede and sticking the bigfoot body on it. In hind sight I wish thats what I would have done. I have the 2WD Pede.Or cud I get a stampede, just stick a bigfoot body on it
Traxxas stamPEDEWots pede
I know I know! I should get 30 lashes with a pull starter ropeHow dare you sir![]()
