That photo is from my gallery. The engine is mounted to an old cybermaxx chassis clamped upside-down, with about an inch cut off the end. The prop is an APC 7" dia x 4" pitch. Mounting it was tough. I had to make a spacer from aluminum on a lathe to keep the prop from hitting the carb, but that left almost no threads for the nut. I cut down the hub of the prop on the mill until there was enough threads. If there is any interest, I could make adapter fittings to thread onto the shaft and hold the prop safely out in front.
I got this technique from the Ultimate Nitro Tuning Guide, which describes the process in detail, and shows a picture of the same bench from Texsavage's link.
Making this was a bit of work, but it only cost me $4 for the prop. I have used it twice now and the technique really works.
But you dont need to go to this much work for proper breakin. Most of the secret is simply to get the engine hot before starting the first few times, and keep it above 200F when it is running. This is to ensure that the cylinder expands enough and doesn't wear too much off the piston on the first couple starts.
