BRAKES FOR SAVAGE X. Should I go Stainless or Fiberglass
TMaximizer
RCTalk Qualifier
Which ones should i get, i currently have stainless, but the pads fell apart
I like the dual fiber ones from the XL. More progressive than the old stainless ones and they hold up for quite a while. They have more grab than the single old disk, but a softer feel to them so they aren't as hard on axles/diffs if you adjust them right.
I am with Olds on the dual Fiberglass. They are not as grabby and the do stop really well. They also last longer than the brake pads that come with the steel brakes. A lot of people were having the problem of the pads coming apart if they spilled a bit of fuel on them. So I am all for the dual fiberglass.
The Fiber discs are the only way to go. CA the edges of them before you install them. Rob some springs from ball point pens and cut them down to about 6mm's. Install them between the brake pads and it will stop brake drag. It extends the life of the brakes and makes them run much cooler and grab more consistent.
