Brake adjustment
Did you get this fixed? It seems to be an issue with the Trx, can you adjust any other settings on it?
It would look like the problem is in the TX. It looked to me like the trim for the brakes wasn't changing on the screen even though you were messing with the trim button. I would try a different TX/RX to test if you have access to one. Otherwise i would just suggest getting a Flysky Gt3B from Hobbypartz. $40 bucks and you get a 2.4GHz Tx an RX with it.
Btw your kit appears to be a XXL as it has the shocks, chassis, and driveshafts from the XXL but the engine if the .26 from the LST2 and the exhaust pipe doesn't even appear to be Losi or at least nothing I'm familair with anyway.
