chuck3
why do you thnk it lasts such a long time?
Anyway, WD-40 does work as a cleaner in a way. I've used it to clean up fuel gunk and nasty buildup on my Aftershock from day one. I usually follow that up with some sort of degreaser like simple green. It will not, however, work to fix a slipping OWB due to the lubrication film it leaves behind. I had this problem once. I tore down my mill to give it a thourough cleaning and guess what I sprayed into the crank case..... you guessed it WD-40. Guess wich problem I had next? Did you guess it again? yup, OWB started slipping.
Congrats qaart, youve become intellegable! keep it up!
