bladder shock issues read on!
rockcrusher
bc
Racing
:first_place:tired of leaking bladder shocks or constantly trying to bleed them properly or setting them for no rebound and it just wont work, that's where I was after dozens of attempts to bleed my plastic stock wraith shocks I was fed up with them.
So I removed all oil and cleaned them up real good I built them the same way you normally would, green slime on the bottom O-rings, three hole pistons this is what I did different, I sealed the holes in the piston so it was a solid piston then the air has to go around the edges of it, lubed the bottom and top of the piston with grease and assembled. no leaks. good dampening, no rebound, and no messy oil, and very easy to adjust dampening.
I have found dampening resistance depends on O-rings used and type and amount of grease. {If your confident that your O-rings wont leak a few drops of silicon oil works great to just enough so every time you fully extend the shock it dips in it and covers the pistons lubed with every flex,{but might be harder to adjust dampening.} I basically turned my shocks into air shocks
Nitro Nerd
Gone - bye bye.
Racing
Good stuff to know.
What shocks are you referencing out of curiousity? Just so I know to stay away from them. ;-) The only ones I have problems setting rebound are the 801XT truggy (TLR bladders help it though).
I agree about Green Slime--it's good stuff! I use it on my diff o-rings and gaskets.
Alexander_0_1
"Roads, where we're going we don't need roads"
Frog Lake A.B Canada
Bashing
What application is this for crawling, rock bouncing, sand dunes?
I'm in the process of checking out/testing the proline power strokes rear slash shocks, and proline power stroke scale shocks, but the place where I got my Bomb Proof transmission parts offers kyosho velvet shocks that I think I must have a set....for a dual proposes.
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
W Shock Help Short Course Trucks 9
Dbproguy Shock kits Buggy and Truggy 0
RookieNumberss Need help identifying what appears to be a bottom of a shock Suspension 5
Coopers87 Sworx shock rebuild issues ? Suspension 2
corneileous Plastic shock ends are wallered out on revo 3.3 Monster Trucks 28
J Baja 5b Shock set up Large Scale RC 2
corneileous What springs/shock oils you guys running for bashing on Revo 3.3? Monster Trucks 2
The RC Car Weird dual shock mod Electric RC 16
Shockwave Lover Do Redcat Volcano Shock Fit on the Recat Shockwave? Nitro RC 0
E Need shock advice for Arrma typhon 3s Electric RC 3
tow_glinka Fitting Shock Springs for Traxxas Stampede? Suspension 10
S Kraton 6s- GPM 7mm shock tower and 9mm tie-rod Buggy and Truggy 0
T Shock oil setup 1/8 Mugen mbx6 eco Buggy and Truggy 1
WoodiE Tekno Shock Standoffs Suspension 0
WoodiE VRP Carbon Fiber -2 Shock Rear Tower for Tekno EB410 Buggy and Truggy 0
S Question about shock absorbers installation Suspension 2
J Hpi ALuminum big bore shock caps busted off once again HPI Savage 1
BurningRain Shock oil weight wt Suspension 2
Y big bore shock too soft Traxxas T-Maxx 8
godale03 Shock Options Traxxas T-Maxx 4
hulkmaxx Maxx shock? Traxxas T-Maxx 3
griff7373 XL 5.9 shock rebuild kit HPI Savage 4
hotrodrob Shock ends Traxxas T-Maxx 2
Japple SC10 front shock questions Short Course Trucks 13
godale03 Emaxx shock options Electric RC 5
hulkmaxx RC 8.2e 16mm shock ? Nitro RC 2
Ckeithnitro 4 Shock Setup Traxxas T-Maxx 7
brunom97 Revo shock oil weight? Traxxas Revo 5
Childresshunt wing mount for flm shock tower Traxxas T-Maxx 7
A Ofna lx shocks 4 shock setup Traxxas T-Maxx 9
A flm shock towers help Traxxas T-Maxx 26
Childresshunt Shock rebuild Traxxas T-Maxx 6
MaxxBlack Shock Tower Traxxas T-Maxx 8
B Shock config... Buggy and Truggy 0
M e revo shock problem Traxxas Revo 11
sur3fir3 question about diff oil weights vs shock oil weights Electric RC 7
hulkmaxx Losi LST Tmaxx Shock conversion ? Traxxas T-Maxx 9
bshobes shock positions? Traxxas T-Maxx 3
V What is a good shock for my nitro rustler? Nitro RC 7
BigBoi87 Shocks and Shock Oil, HELP ME PLEASE Nitro RC 9
rak12 shock towers? Traxxas T-Maxx 10
P shock shafts?? HPI Savage 3
G Shock oil Nitro RC 2
W Help, Arrma Raider front shock Arrma RC 5
M HPI shock. HPI Savage 3
WoodiE SCX10 Rear Shock Relocation Kit from Gear Head RC Scale RC 2
SchrodeMode Big Air Shock Set Up for Rustler Nitro RC 3
TaterX Lst shock conversion vs HPI big bore HPI Savage 9
Bkyd Basher Shock ends Traxxas Revo 2
E Best Touring Shock and Suspension Tune-UP for HIGH SPEEDS Nitro RC 0
