Hi All,
I have an engine leak (HPI Trophy 4.6 stock). After running the car the last few times I noticed what looks like burnt fuel (basically oil) under the engine. There was a pretty good amount of oil there. It is important to note I had been running the car very rich (both LSN and HSN) to reset the tuning process.
Removed the engine and inspected closer. No leak from the exhaust gasket.
I then removed the pull start and the inside of it was covered with burnt fuel/ oil. I inspected the back plate in detail (which was also covered in oil) and it seems the oil is coming from either the back plate screws or the starter shaft opening. It is difficult to tell because the whole area was pretty dirty with oil.
When I removed the back plate I noticed a lot of burnt fuel accumulated. I also noticed burnt fuel when I removed the exhaust, so the car was running very rich…
I’ve recently sealed the back plate with silicone sealer (Permatex Utra Copper) BUT I didn’t really seal the screws.
Could the leak coming from either the screws or the starting shaft opening? What can I do to stop the leak? I posted a few pictures for quick reference….
