Big Engine Wanted....
eartaker
Tacoma, WA
Ok so I upgraded everything on my savage X that was plastic to aluminum except for that radio box :\ . Anyway the point is now it is heaver and I'm in need of more Power. I placed a new Axial .32 in it but I'm afraid it just wont be enough for me. I was looking for something in the ohhhhh .5 range is there anyway to convert a helicopter engine or do they make an engine this size to fit into the savage?
May I ask why you wanted to replace all that was plastic with aluminum?
Doing such a thing makes it look strong but in fact can be more harmful to your wallet in the long run.
STS.30DM is as bad ass as your gonna get, a heli engine won't have enough RPM's to get the speed you want.
truthfully......it looks pretty lol. I'm in the Army stationed in Korea and I have nothing better to do. but I'm taking all the plastic parts and building another savage with them so I have one to show off and one to bash like a mad man with. What do you think of the .46 that come stock on the CEN Genesis
Those .46 engines are just torquey. I would suggest an OS 30 VG or an STS 30. I have run the STS 30 on my old savage but it was not as "pretty". It moved it fine for me.
New era makes a conversion for the .46 (Genesis) or .70 (Ek4) engines. I have wanted to do both in a savage, just for the heck of it!
wow .7 hmmmmm
they PRO-70 engine only runs at max 17000 RPM
Axial .32 Engine Specifications
Size .32cubic inch
Maximum RPM 34,000
Bore 19.5mm
Stroke 17.5mm
Construction ABC
Heat-sink Head Green Anodized Aluminum
Carburetor 9.0mm Composite Slide Carburetor (includes optional 8.0 & 8.5mm venturi’s)
Carburetor Adjustments 3 Needle, Flush Settings
Case Black Aluminum, Rear Exhaust
Connecting Rod Dual Bushing
Sleeve 8 port
Starting system Pullstarter
Recommended Glow Plug Cold-5 Power Plug
Model Name: O.S. 30VG(P)-X
Options: 30VG(P)/Starter Box, 30VG(P)-X/Pullstart, 30VG(P)SR/Savage
Part Number: 13970 30VG(P)-X
Price: $270.00 (Approx. Street Price)
Displacement: 0.298ci (5.0cc)
Bore: 0.728" (18.5mm)
Stroke: 0.717" (18.2mm)
Practical RPM: 4000-36,000rpm
Output: 3.0hp @ 28,000rpm
Weight: 14.4 oz. (408g)
Carburetor: 21E Slide-Valve
Glow Plug: O.S. #8
NX 76 Engine
Displacement: .46ci
Ports: 3
Rear Exhaust
Starter Type: Pull Starter
Carburetor: 2 needle slide
Crankshaft: SG shaft
Piston / sleeve: ABC
Red-anodized cooling head
Horsepower: 5.0hp @ 23,000rpm
what one would you guys go with if you had a choice?
of the engines or my truck? of those engines I have a the Axial .32 in the truck right bow but has never been ran so i don't know what the output will be i will finish up the truck tonight and take pics of it.
wow .7 hmmmmm
Size .32cubic inch
Maximum RPM 34,000
Bore 19.5mm
Stroke 17.5mm
Construction ABC
Sleeve 8 port
Glow Plug: O.S. #8
NX 76 Engine
Displacement: .46ci
Ports: 3
Rear Exhaust
The OS.30, the bearings in the Axial are no good, they fail around the 8 gallon mark and can't handle any RPM higher than 32,000 and the NX 76 just sucks. :whack:
The OS.30 is a damn good engine and will last a long time provided you don't over lean the engine and pre-maturely burn the bi-metallic liner in the sleeve.
hmm ok well i want something that gives me about twice as much power as the K4.6 engine. what would anyone suggest?
I want to see the whole thing man. It sound sweet.
Bryson
Getting twice as much power as a K4.6 into your truck is probably not a good idea. Any engine that has that much power is not going to be reliable, its not going to spin very fast, and will probably destroy your truck more often then moving it.
Your best bet is to go with a nice 30 or 32, such as the OS .30.
wow .7 hmmmmm
Size .32cubic inch
Maximum RPM 34,000
Bore 19.5mm
Stroke 17.5mm
Construction ABC
Sleeve 8 port
Glow Plug: O.S. #8
NX 76 Engine
Displacement: .46ci
Ports: 3
Rear Exhaust
those horsepower claims are :thumbdown
STS .30 is going to be more powerful than the axial .32. A modded D30M is DEFINITELY going to put that axial to shame, along with most of the other bigger big blocks.
you want twice the power of a 4.6, put two engines in it!! youve already said its the pretty one, so go true shelf queen and do the truckzilla dual engine mod.
The OS 30 is a screamer. I saw one once in a savage X and it was nice... The guy couldn't drive or tune to save his life, but the truck had good power and the engine had legs to carry the top speed well.
If I can rationalize spending $200+ again for a basher engine, the OS30 will be it. I've had bearing issues with the OS21RG, but the 30 is a much better built engine. If it tunes as easily and holds a tune as well as the old 21RG, it would be a great engine out of the box. Then, if you have the $, send it to someone reputable to get it polished/ported and it would be nuts.
the sts .30 is a good engine, wannarunem had one on his storm buggy and man that thing screamed. i have the os 30 on my savage x but i havent even broke it in yet. i feel like eddy and the chriscraft..... :(
the OS .30 is a joke of an engine for its size. Even Mid Tier .21s can smoke that thing.
