Better Performance w/ out Pipe?!?!?!?!
Buggyracer28
Portland
Hi, just a quick question. Will an engine run better without a pipe or manifold? Please someone give us a short answer (explain) why this is or is not true. thanks.
you would have very little if any back pressure, and you need a chamber to equalize pressure in the engine. ask him to show you and run his RC without a manifold and pipe. if he doesn't have one ask him how he would know
Buggyracer, how would you deal with the back pressure? Also the engine would n ot run correct. THis isn't a big block where you can remove all the restrictions and run like a bat out of hell.
an ace outlaw pipe off ebay gets no back pressure. i have one and my truck can't idle and it takes a while to get to top speed thats why today i'm going to my lhs i have a list and $100
Thanks guys for the info! I knew the engine wouldn't run right w/ out a pipe. Thats why i wanted to ask you guys to make sure.
While backpressure is mostly correct, there's a little more to it than that.
Offroad bike racers found that by cutting off their exhaust pipes, they could get more power out of their engines in different power ranges. This idea evolved into the "tuned pipes" of today.
Because of the way two stroke engines work, a great deal of fuel would ordinarily slosh out unburnt if not for the effect of scavenging, a combination of backpressure and sound waves in sync with the engine that returns unburnt fuel to the combustion chamber.
There are a great many studies and documentation (even on the web :) ) into tuned pipe theory and it was discuvered it was not only the alteration of backpressure that enhanced an engine's performance, but more importantly the sound waves eminated by the engine and how they are echoed back to the engine through the tuned pipe. To really work correctly, a tuned pipe's sound waves must be in sync with the engine; the length must be adjusted, and every engine will act differently with every pipe.
This is why you'll seldom see me comment in most "what's the best pipe" threads. You can't tell without being there, you have to hear and observe, as well as hear and observer the stock manufacturer recommended pipe for a baseline comparison.
There used to be a cool applet out there, but it's since dissappeared. Here's a great one-pager on tuned pipe theory.
lst year i straight piped my gt it had an os 12 i work at an exhaust store so i fabed a pipe in the same size as the header then put a hole in it for the fuel tubing it idled and ran awesome had alot more power but couldnt stand to drive it it was so loud even at idle you had to yell at someone standing right next to you thanks just my two cents ps went back to muffler track said so
