Better handling for SAVAGE XL
Soheil
hi everyone,
what do you suggest for better handling for savage xl with stock shocks and arms?
for example which position should shocks be on shock towers?
i want to have better handling in asfalt!!
if you attach some pics it would be better for understaning!!
thanks!!
Set the suspension to the lowest setting. Thicker shock oil would help as well. You want low and stiff for on road use. Don't expect it to handle like a sports car though.:)
Get a touring car. Slow down when you turn.;) You may be able to find a sway bar kit. The Savage certainly wasn't intended for on road use. No matter what you do, it won't corner like a car.
if you can find a low profile tire and rim combo that fits, it will help as well. The stock tires have really high side walls that, even with the shocks at the lowest position, will roll under in cornering and cause a flip.
get a set of sway bars and proling road rage tires with some new rims and lower it and youll be good to go
