I have ran the following:
Stock blue pipe that has the stinger drilled out
2 chamber resonator drilled out
2 chamber resonator drilled out with the internal baffle removed (now single chamber resonator)
Trinity high flow without the stinger reducer
Fantom works
All of which with the traxxas spring mounted header with a slightly cut flange.
I really like the power of the trinity, but the noise is unbearable. I'd try putting the stinger reducer in to see if it helped with the noise, but I can't find it. The fantom is close to the same performance but may actually be louder. Stock and 2 chamber resonator really make power output suffer. Single chamber resonator is my compromise between power and noise.
Basically, I want the low end torque of the trinity with the sound of the drilled out resonator.
Anyone have any experience with anything else as a comparison? I've read the THS pipe is a good one, but haven't found much by way of people that ran it vs the trinity or what it's sound level is equivalent to. I have to care about loudness due to the places I have to run.
Fantom works
