Streaker
RCTalk Rookie
You can use the stock pipe but it will choke the picco(Also run a greater risk of blowing seals). You can use a THS 146B rear exit pipe which will require an adapter from Racer66 on this forum(about $20). For the biggest power boost you will need to install a 086 side exhaust. I run the THS 146B and it is crazy fast...
(The Picco has a small block exhaust port, so for any true BB exhaust you will need this adapter. It works great)
I will have to order a pipe in the near future.
I cannot find racer66 on here? Searched username and no luck? Does he fabricate his own adapter for these BB exhausts?
