On the contrary, running your engine below 200 can cause just as much damage as overheating. Try to get it to stay at least at the 210 mark. Too cold of an engine will not allow the sleeve to expand completely and cause premature wear on the engine. 195 is not too bad, any lower than 185 and it would be an issue.chevy_87 said:yep i run O'Donnel 20% love every drop of it...also gauranteed to keep ur engine under 200 degrees...which means more engine life...and i ran it in my maxx and i tuned and it kept 195 to 196 all day long...
chevy_87 smartest guy around here with engines.. [/QUOTE said:Your in trouble my friend If he is the smartest guy around.
If you also did your break in at those temps, you NEVER broke it in. Be prepared for problems down the line, and a very short life on your engine.chevy_87 said:i ran it in my maxx and i tuned and it kept 195 to 196 all day long...and for some reason to me it helped my 2.5 engine hold a good tune and I didn't go through glow plugs except for one and thats when i broke my engine in...
I race as well (on-road) and I do know what keeping an engine at that low of a temp will do. I have seen it "mushroom" the top of the piston because the sleeve was not run at operating temp. All my engines are highend italian engines and each and every one of the manufacturers of my engines(Mugen, RB, Novarossi) say to hit 190-210 for break-in. Optimum power vs wear temps, will range from 220-250 degrees. Anything less and it'll be rich and will run like a e legged horse. Not very efficient at all.chevy_87 said:nope the guy at the lhs said keeping it under 200 degrees will give you a longer engine life and he races 1/8th buggies 36 weeks out of the year and he is the smartest guy around here with engines..and I'm pretty sure cause he races that much he knows what he is talkin about...
But the performance could've been better ... I can pretty much safely assume that. Over 5 gallons (probably leaning passed 6) on the RB V12 sitting in my car and it can and does, still hang. 5 gallons is average life for an engine.chevy_87 said:well if there is enough lubrucant in there it doesn't matter how hot and plus when engines run cooler means more power..so I have done this for a long time matter of fact for about 5 gallons on my RS4 and it had so much power and ran so good and held a good tune..so thats what ill stick with running and keepin it under 200....
