Battery suggestions
ronnyc00t
Mackay
  3. Crawling
Hey guys probably been asked a million times, did try a search but could find what was after. I’ve got a rival mt10, stock motor and esc, currently run a 11.1v 3300 and 5000 lipo.. what’s everyone running and should I be trying anything different
Only upgrades so far is 20kg servo, ally steering rack and ally shocks
What are people running on their mt10’s
Are those shocks in your front too? Where the swaybar problem is?
Thinking they might be too long... would cause marking on your cv's and could make your droop pull the sway links out. Just a theory... measure and compare those shocks.
Haven’t installed shocks yet but they are the TA factory upgrades not cheap knock offs ones. From what I can see nothing is loose, broken or worn. I got some pics, looks definitely like the sway bar is touching somehow but I can’t get it to touch when I move it, unless the wear marks were from when the links were missing
The rear sway bar is super close to the cvs too
Or do I just need to open up the links a little further so there is more clearance ?
I forced them abit harder and can adjust them, I tried yesterday but didn’t want to force it and break it
Measure your battery tray & look at dimensions of a listed battery make sure it will fit. You might find a 6200 or 6800 or 5800 etc. I even have a 7200 6s battery. It's huge.
Appreciate the help cheers
It does look like youve got some marking there... thats my bet on loosing arms...
I don't own one so I have nothing to compare pics.
No impact on suspension compression though? What about 1 side then other seprately?
Both side the exact same marks
I’ll loosen off after the gym n then compare n give it a run see how it goes
