battery pack questiion
Who manufactured the radio that comes with your RTR?
The answer is Ace and the one you want is "C"
Thanks, all I saw was the jaguar on the picture of the kit.
if you are using a standard switch with the small red plug on the battery pack for the radio get plug "A". if you are not using a switch get "C" it will work in just about every radio, even the futabas. you will just need to make sure you have the wires on the correct side.
crap that means that I will have to do away with my switch cause i already sent of for switch C, oh well I guess unplugging works fine 2
yeah actually most racers i know just unplug it anyway so you dont have to worry about the switch failing or being turned off.you can however take the prongs out of the "C" plug and the one on your current pack, then switch the plastic pieces. just use a hobby knife to push down the small tabs that you can see on the plug and pull out the wire. and make sure you dont cross the pollarity!
