Thanks for responses.
Acutally, the actual output from 4 NIMH cells are 5.86V according to my digital volt meter and even ultra high torque servo works fine w/4.8 V according to the spec.( about 20% slower)
SPECS: Speed: 0.24 sec/60 degrees at 4.8V
0.20 sec/60 degrees at 6.0V
Torque: 106.93 oz/in at 4.8V (7.7kg/cm)
133.31 oz/in at 6.0V (9.6kg/cm
This is a Hitec, Ultra Torque, Metal Gear Servo with a
Hitec, JR, or Airtronics-Z Style Connector.
FEATURES: Three metal gears.
Dual ball bearings.
Metal 1st Gear.
Four adjustable splined horns.
For use with .60 size helicopters, gas or electric cars and boats.
INCLUDES: One ultra torque servo with 11.5" connector wire.
One white small X-shaped servo horn.
One red Large X-shaped servo horn.
One white adjustable servo horn.
One white off-set straight servo horn.
Four 2 x 14mm mounting screws
Four brass eyelets
Four black rubber vibration isolators.
REQUIRES: Hitec, JR, and Airtronics-Z radio system
133.31 oz/in at 6.0V (9.6kg/cm)
Length: 1.59" (40.6mm)
Width: 0.77" (19.8mm)
Height: 1.48" (37.8mm)
Weight: 2.11oz (60g)
