baja wear&tear
jimmy j
hi,could do with sum help!
rear lower arms r damaged from jumping,wheels flex on landing and rub on lowerarms-have replaced with new ones!
it has also started cutting through the plastic bit of suspension
at the end of shaft holding the metal ball.
does the whole shaft need changing or can i change the plastic bit holding the metal ball?where it connects to lower arms???????:\
Then you will need to replace the entire shock shaft since the ends are molded on the shafts themselves.
I am new but i also think it is for front or rear... obviously rear is longer so watever u need front or rear, i gave you both links....
Keep in mind there are also 2 different shock shaft diameters.
The original RTR shocks uses 4mm shafts while the SS, RTR 2.0 and T use the 6mm shafts.
thanks for ur help,i have the original rtr,so i will need the 4mm?:)
hi,u say they r molded to shaft!!!!! item number 85410 shows both ends of suspension? i see it is more expensive than ur item u said to get,but all i need is the plastic ball holder at the bottom of suspension,,,,,,,is it a hard job changing ENTIRE shaft??????
thanks,sorry for being a pain!:\
