Well, I bought it. I installed it in my mammoth. Had to change all my linkage which was a PITA. Wasted an hour there...
Took it out, put a sock over the head (it's 50F degrees here), primed it and it started on the first pull.
Drove it around slowly trying to get the temps up for the first tank. Took about 4 minutes, most of which at WOT, but it was so rich it barely moved. Temps only got up to 110. Let it cool down to 70F with the piston at BDC, ran it again after leaning the HSN about 1/4 turn. This time it got up to 125. I leaned it a bit more for tank three to get the temps up to 180.
At about 500cc's of fuel, it started to open up a little better and clear its throat on an extended WOT run. Around 700cc's, it was spinning all four tires on pavement and idling smooth.I ran around 900 cc's of fuel through it so far. Temps were around 220-230 through the last couple of tanks and it was screaming. It's still a little muddy in the middle, but that got better and better with each tank.
All in all, a pretty decent and easy break in.
BTW, my mammoth is a single speed with a center diff using 50K oil with 13T/65T gearing. I could probably get away with 14T or 15T, but I need to get a new clutch. I'm using mugen shoes and they suck. They are only about 3 quarts old and they have been constantly dragging for the majority of this breakin.
