anybody run the .20 head shim?
If you want to run the .20 go for it, but after some running pull the head off and check for pre-detonating/pitting on the button and piston.
thats just it i think my style of driving i would perfer the .40 don't care bout top speed i do alot of rock, hill climbing and think the .40 would run cooler and have a lil more torq.but the .20 would make it scream but sacrifice engine life.and what bout temps?i know the .20 would run hotter than the .40
To do it properly the deck clearance should be measure first, then you shim it accordingly. Taking out shims without knowing what the specs are is about as dangerous as cranking your boost in a 1:1 with no wide-band or tuning abilities. It just costs less to rebuild or replace. :)
lesclaypool's example will work but I would get it up to temp, put a performance tune on it and run it really hard for about five minutes. That's all it should take to show signs that it may be pre-detonating.
I would leave it stock. It sounds like you're expecting a miracle to happen with a 3.3, when in reality you will barely see any difference in performance.....and it could be less performance at that.
yes run it today it was 70 degs. and had a performance tune on it and with the .20 it started per=deadnating.so i guess i'll try the .40 just to see what that will do.think i'm gonna go with the picco .28 w/mount off ebay for $200.but i've only ran 2 gals. in my new 3.3 so probaly just buy the picco .28 and run the 3.3 till it dies.
