Annoying Carb!!
nasir
RCTalk Champion
England
Hi how is everybody doing. I am quite stuck. I just bought a GX5R Nitro engine and can't get the Carb to move. I have taken the bottom screw out.But no luck.I just need to move it so i can fit the servo on.
Any help would be much appreciated.
Thank you.
Yeah try pushin it in and out,if you have to, add a few small drops of fuel and pushh n pull it thats what worked for me
You took the screw out for the cinch bolt? Try putting it back in, tighten it until it's finger tight, then back it off a couple turns and push on the screw with your screwdriver. This usually unlocks the cinch from the carb neck.
