alignment
Bkyd Basher
Stamford Ny
I was adjusting the tow and can't seem to get it. I turn on the car to center it up and have the dial on 0 and do not have enough adjustment to make them straight.Passenger side is way out and driver side is Maxxed in. Had to compensate with the dial. Am i doing this wrong or missing something?
More info would help.
Check your pivot balls that the wheels turn on. If you have them not matching side to side, it will in effect make one side longer/shorter which has a fairly drastic effect on your toe. A turn or two on the pivot ball makes a big difference.
Start at the beginning....
disconnect the arm from the servo. Turn on the Tx and Rx and center the trim switch. Align the front tires visually and reconnect the servo arm. NOW adjust the toe.
