Sold / Found * Airtronics MX-3 FM Radio+Receiver+Servo for Sale
Status
Not open for further replies.
Digital Liquid
Wilmington, NC
I have a BRAND NEW - STILL IN THE BOX - NEVER USED - Airtronics MX-3 Radio/Receiver/Servo for sale. It is the 3-Channel Version on 75MHz FM Frequency. It comes on Channel 84 (75.870). It has all the bells & whistles you can need. It's a perfect upgrade for any T-Maxx, Savage, or any touring car or buggy.
I will take $125 and that includes FREE SHIPPING. :2cents:
You can find some specs below & email me for any further questions @ [email protected]
Thanks.
This is the Airtronics Mx-3 3-Channel Computerized FM Pistol Radio
System with one Standard 94102Z Servo.
FEATURES:
---New "Z" connectors compatible with most other brands although not compatible with older connectors without adapters (see comments)
---Large easy to read LCD display on rear right of transmitter
---5 model memory
---1-touch digital trims with memory and shown on adjustable LDC display
---Adjustable trim rates
---Adjustable servo speed to speed or reduce response
---Exponential adjustments for steering and throttle
---End Point Adjustment (EPA) independently adjust the endpoints for the throttle and steering
---Narrow band
---Adjustable 70/30 trigger
---Non Slip rubber steering wheel
---Servo reversing
---Sub trims, trim reset, wrist strap hook
---Nicd charge jack at rear of transmitter
---Audio Beeps can be turned OFF with simple startup procedure
---Adjustable tension on throttle lever with simple screw adjustment
---Null Zone adjustement for trigger
---Power indicator lamp with audible alarm under 9.1 volts
---1 year warranty
---Cartridge type battery tray to quickly change batteries
INCLUDES:
---One 3-Channel FM Transmitter
---One 3-Channel Receiver
---One Crystal Set (Channel 84: 75.870MHz)
---One 4-Cell AA Battery Box w/Blue "Z" Connector(not BEC)
---One #94102Z Standard Servo
---One Switch harness (ON/OFF switch)
---One Frequency Number Flag
---Four servo arms (One Large X, Two Small X and one six sided)
---Eight brass eyelets
---Eight rectangular rubber grommets
---Two servo arm (horn) mount screws
---One Instruction Booklet
SPECS:
---One FM 3-channel transmitter
---Receiver: 42mm (1 21/32") x 27mm (1 1/16") x 22mm (7/8")
---Frequency: 75.870MHz
---Modulation: PPM/FM
---Power Supply: 8AA
---Connectors: "Z" type
Is this still for sale? If it is what about 100 shipped?
Status
