air leak sealing questions
Thanks guys, The picco .28 it will be. I've heard only good things about it. About breaking it in, what method do you recomend for this motor?
Hopefully soon i will be hearing back from HPI, but bought a picco .28 p3 while back home in MN for christmas. Now i need much clutch assembly and motor mount to break it in.... I can't wait!!!
Good choice man, open up that Picco and look at the quality inside. Check it for machining debri and flush it out good.
Ok a tech guy called me up yesturday and said that the clutch had a defect in it and that the one way bearing was bad si they fixed tit up and it is on its way back.. Finally.
