Prob the tank lid or you have a pin hole in your fuel line. What rig you running? 99% of the time it is your lid on your fuel tank it has a small o ring that is pron to going bad. Best way to check is remove the fuel tank put it under water and plug one fuel inlet with your finger and attach a piece of fuel line to the other and blow if you see air bubbles there's your prob. Remember if you can cause your fuel tank lid to leak by blowing then your engine can cause it to leak your engine is producing 50-70 pounds of pressure.
