Aftershock/LST2 Engine Mount Screw/Bolt size?
Nor_Cal_Guy
My truck decided to let the stock ones free and now I'm DIW. Anyone know what size they are? The part numbers are A6240 A6350, however Losi Parts are hard to come-by and I just want to get it going...
Pretty sure they are 4-40, and in my experience, HobbyTown employees aren't the best to take advice from.
The part # you gave Losi crosses to a 5-40. I checked my set that I have,it has 4-40 in it but they are loose. I don't have a 5-40 here at the house but I will check it thoroughly at work in the AM and let you know tomorrow.
Hobby town people sometimes suck they just tell you this tell you that just to sell you something and go. Lol I'm new but not that dumb
Interesting. After work I'll see if I can find my 454 mounts, they still have the original screws in them, and I'll gauge them.
LST Engine Mount Bolts
The correct size is 5-40, it is the same as the shock mount bolts. 4-40 is too small.
Cheers.
Sorry about my misinformation. I had drilled mine out a long time ago and use 4mm. Did the same with my upper shock mount bolts. Everything else I replaced with 3mm.
I have been to a hobbytown, an ace and a truvalue...no luck.
Damn loosey Losi. Well 5-40 it is then!
