after run oil or WD40?
cooldude
RCTalk Racer
so whats better to use after run oil or WD40..? i see people use both whats really better to use on motor/carb after done playing?
thanks:bow:
i don't really know which one is better but i presume that after run oil is better because it is specifically designed for the engine after running. Although I just use wd40 simply because you can use it for everything!
I would just stick with ARO. Essentially, they do the same thing. WD40 displaces moisture which you don't want. ARO is not expensive by any means so I can't justify using anything else.
couldnt have said that better myself Lessen!
listen to him, he knows what hes talking about!
I go with ARO, especially since thats what my LHS gave me with my truck. Although from what i've read either is fine.
