ztugdriver
RCTalk Rookie
Hello
I’m am trying to reverse engineer an electric fishing reel that uses an RC motor and ESC. I’m just not sure how they configured the ESC to run on a 12 lead acid battery. The current setup is a 4130-400kv motor unknown brand, eflite 60 amp ESC, wireless receiver for a remote control dongle(not going to use it in my setup), micro maestro PMW controller and a potentiometer. I will list my components below that I will be using.
My first question is what would be the recommended settings for my ESC to run on a 12 volt lead acid battery charged by the boats engines while being used so voltage will be between 12-13.8.
Second anyone with experience setting up the micro maestro PMW controller with a potentiometer input. Can I hook it up to my laptop and get its current configuration of the one I have? The manufacturer has free software to configure the controller I’ve just never used it before.
Third is there a better or easier way to control the ESC with a potentiometer other than the PMW controller they use? Could I reliably use a servo tester?
My set up will use the following components:
Tempest 4130-400 brushless motor
https://innov8tivedesigns.com/tempest-4130-400kv-brushless-motor.html
Micro maestro
https://www.pololu.com/product/1350
Potentiometer not chosen yet but off/0-100%
Any input would be greatly appreciated.
BadAss Renegade V2 Series Brushless ESC, 85A
https://innov8tivedesigns.com/badass-renegade-v2-series-brushless-esc-85a.htmlMicro maestro
