idanha rambler
- Crawling
- Scale Builder
For those that have a crawler and need weight added here is a idea for you that I use and I found it works really well. Wraping solder around the rims then using a bit of hot glue to hold it in place works with most of every rim and tire that I have used. You can add as much as you won't just trim the foam and put it over the solder. It keeps the weight down low,makes the shocks work better and helps with traction. Below is a example of how I do it.Crawl on everyone
