Adam Drake
Originally posted by Çh®i§tiªñ
Where is the backpressure fitting? Its it on top of the lid itself or on top of the tank? If its on the tank and not the lid, you can either mod the tank or buy the newer version. This eliminates the backpressure pissing of fuel into the exhaust. Easy fix, but, can be frustrating and cause excessive stalls if left unfixed.
Break-in temps I like to keep below 250 but no less than 180ish. 225 seems to be my happy spot.
It’s on the tank do you have a link for the other tank? I’ve been keeping the temps at 220 so I’m on the right track just was not sure if it was different than a .21 thanks
http://www.thedrake.net/pictures/DSCN3796.JPG
There is a pic of the new tank.
Find an LHS in your area that will order it for you. Its the exact same part number as what you have, however, if the LHS orders it you seem the get the one with the fitting on the lid. Online, you can't tell.
Not to mention, if the wrong tank shows up, the LHS can send it back.
The other option would be to tap your own fitting.
Just got one off of ebay from someone named Fasteddy. At first I thought it was the one from here until I saw he was from Arizona. Or was he:D
i might be gettin a xxx-nt drake edition but i dont what engine to put in it i have bookmarked a few but I'm a newbie so i dunno if they will fit/work with the xxx-nt
1)http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXAGD0&P=7
O.S. .12 CV-R (P) w/10C Slide-Valve Carb
2)http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXALM4&P=7
3)https://www.ssl-stormerhobbies.com/cgi-bin/seekpart.pl?pn=FAN01003
Fantom FR15 NITRO ENGINE, PULLSTART SIDE EXHAUST, ROTARY CARB
same goes for the Radio system with 2 servos i dnt even know what servos are so as you can see help is needed so and help would be apreciated
With the AD xxxnt kit and extras i'm up to 800 give or take.
This is the finished project.
where could i get a clear body or is there such thing and where did you get that body or it it just the graphite colour that comes stock
Not at all! You can get some Lexan scissors, or if you have a Dremmel that works great too! Personally, I roughly cut around the body to remove most of the casting, then use a Dremmel to make it look perfect. If you do use a Dremmel, practice some first if you don't already have a steady hand with it. It will get away from you if you're not carefull!
No - you are asking for trouble if you do. Jagged overcuts etc..
Either get some lexan scissors or a dremel tool with the right bit.
how would you use a dremel like what attachment and would you clanp the body some how to keep it still or what
Man, i like it :OMG:
Do these things like to donut.
How do they compare to the 4wd's.
Kyosho 1
Kyosho 1
yes they do donuts like no tomorrow.
