adam drake 1 or adam drake 2
RevoRider
is there that big of a difference between the 1kit and 2kit for the xtra 100 dollers
:cheers:
Hey RevoRider, I found this on this website: http://forums.radiocontrolzone.com/archive/index.php/t-186004.html
" - New rear axles with standard and quick-change wheel capability
- Extra strong VLA+ multi-adjustable rear suspension arms
- Machined aluminum multi-adjustable rear hubs with vertical ball studs
- Oversized rear axle bearings
- Cross Bones universal driveshafts
- Stronger VLA front suspension arms and carriers
- New alloy steel front axles
- Wheels that can be used on either the front or rear
- Machined & lightened hard-anodized aluminum chassis
- Hard coated one-piece aluminum slipper/topshaft
- Kevlar spur gear & New Heavy Duty thrust assembly
- Hard anodized low slung rear exhaust header & tuned pipe
- Titanium Nitrided hinge pins throughout
- Machined aluminum shock adjuster nuts
- Stylish AD2 Stadium Truck Body
The AD2 also benefits from revised materials and molded parts for greater strength and durability necessary for today's high-powered nitro off road racing trucks. Special attention was given to produce much stronger shock towers, rear pivot, suspension arms, and battery box. In short, the new AD2 has better traction, stability and rough track handling than you ever thought possible. The unmatched combination of the improved durability, easy adjustment and power handling performance makes it easier to drive"
hope that helps...
-Pat (redhatman)
The extra money is most definatley worth it. It handles better and is more durable. If you're a racer, spend the extra.
