CountryNitro
So I dug my Tmaxx out from the garage and drug it down here to college so I could get it running again in my spare time. I've got the truck running, and am fine tuning it for the colder Cleveland weather. I've got the high and low speed fuel mixture done alright for now. But when setting the idle, I read that Traxxas wants the engine to idle without any input from the servo (they say that the throttle trim on the remote should be holding the brake whilst adjusting the idle speed screw on the right side of the carb). And i mess with the screw, not knowing which direction does what honestly. And either way I spin it, it doesn't seem to make any difference. So then i give up and just adjust the throttle trim on the remote to keep it running. Which is faster and easier; Until you hit the brake and the engine stalls. Also, on a side note i can't stop my steel spur gear from slipping. It was installed shortly before the truck was stored. And i keep adjusting it to no avail. Its not skipping teeth. The gear backlash is pretty well set.
Any help you guys can provide would be greatly appreciated.
