8.0 steel clutch
darein40
ok i just got the new steel clutch for the 8.0 and i just love it. so here just to say that if you need to replace your clutch get the steel clutch for the 8.0. no more shoes..
I thought the 8.0 had an aluminum 4 shoe clutch to begin with. How much did the steel setup cost?
yes i used super glue and it has held good so far
---------- Post added at 9:44 AM ---------- Previous post was at 9:43 AM ----------
it is cheaper than buying the shoes.
my 2 cents. I got sucked into the steel clutch and after splitting two of them in half I went back to the aluminum clutch. It may not grab as hard but it works consistently.
i used electric tape around the clutch and glued the shoe the the bell housing then inserted the in the bell to make a tight fit after the glue had dried remove the tape and your good to go.
