I know not many of you have one of these yet, but for those of you that do here you go, they finally got around to getting er done enjoy! Hey mods if this is not exceptable please move or do what you need to do to make it right thanks Itsme!
With smudgy or wet underground there the driving fun takes a sudden end.
This problem took the company Modellsport hot into the hand and developed a singular and never here been all wheel system for all usual Offroad fG of models.
After some attempts hot Tunning created a chain-claimant all wheel system.
After approx.. one year probebetrieb one came to the realization that this technology must on the market. Some customers of the company Heiss tested the new all wheel principle with its vehicles and them were simply only overwhelmed.
so the converted version could look
After hard however successful development time stands production stages for the all wheel system nothing more in the way.
All conversion parts are made with CNC machines of high-quality materials.
Each Offroadfahrer, which knows the handling of an all wheel car, transferred and for reasons of the reliability of a petrol engine in a Groeschl model, finds with the again conceived all-wheel drive both in one.
contain in the change set
Front axle with special ball joint
As said, each Offroadfahrer, which does not have this all wheel set yet, should procure itself immediately one. The propulsion principle was patented.
Hot Tuning wishes much fun!
Leopard Race/Cobra 4wd - platform
(all wheel Umbauset completely installs Race Buggy for leopard)
Bestellnr. 14062003HT/LR € 850, -
Monster Truck/Cobra 4wd platform
(all wheel change set completely installs for monster Truck)
Bestellnr. 14062003HT/MT € 850
17. Manufactures shock absorber
18.Stossdaempfer insert
19. Drivers install and with screw locking fasten
20. Remove servo plate between and
21. Body owners and receiver box install
22. Original disk on new servo Saver - axle put
23. Tie rod exchange
24. Complete steering element and tie rod on the interior drilling of the
Knuckle install
Each Offroadfahrer had problems with its model of fG surely already its.
completely rebuilt front axle
Building guidance monster - Truck
1. Body remove
2. Tire - overroll bar retaining plate Daempferbefestigung
dismantle
dismantle
3. Side parts diminish
4. Tank and engine remove
5. Complete rear axle remove differential infer
6. Screws loosen, differential case remove
7. Chain wheel case out of platform take
8. Differential into the chain wheel case push in
9. Screws with screw locking (high-strength) tighten
10. Assembled differential
11. Complete differential into the chain hang up
12. Together, wishbones build rear axle with differential
bolt
bolt
13. Differential supports bolt
14. Manufactures rear axle
15. Front shock absorbers divide
16. Piston rod with distance piece and plastic parts also
Screw locking install
Knuckle install
25. Servo insert
26. Intermediate plate with body owner install
27. Engine supports install
28. Engine insert
29. Spacers at the overroll bar install
30. Overroll bars and side parts screw on, hoses fasten
31. Manufacturer 4wd monster - Truck
