Well i ordered my 3 speed on friday and it got here today! it was brand new off a Savage XL. I get it all installed and everything goes fairly smooth. I know i will need to change the shift points but i'm not sure how much so i rev it up and i get no shifting. Just 1st winding out. cool. i pull the top off and get the gear assembly in my hand. i pull out he setscrew that holds the cross pin in on 3rd gear. I slide my 2.0mm driver into the crosspin and give it a turn, all i get is the feeling that it slipped and when i pull out the driver it is covered in shavings!!! the allen head on the crosspin basically crapped out on me in one turn. needless to say, i am rather annoyed right now. I pull the assembly off the from other side and i am just able to back out the 1-2 shift a turn so i can still adjust the shift points but it takes another few minutes. I am just mad that the pin head fell apart so easily. i had a solid bite on it and it just chipped off the sides. Anyone else have this happen?
Also my 1-2 is rather quick but 2-3rd is perfect. should i wind out first before it shifts or should it shift at about mid-rpm range.
