ozziii
RCTalk Qualifier
- N/E Victoria, Australia,
- Racing
By the looks & sound of it I have had the front bearing start to fail, it was making a winding sound & leaking a bit as well. I will probably just rebuild the engine but would like to know what bearings I should put in it, I would prefer something better than standard, & either stainless or ceramic, is it worth putting ceramics in it or will they not last as long as good stainless bearings.
Is there a better than standard piston/rod/sleeve combo available or just the standard stuff. The engine was still running fine & the piston & sleeve still look good, although it was getting easier to turn it over using fingers so compression is probably not as good as it could be, still went real good though & no black gunk on the piston, just a goldy bronze colour.
