$20.00 for a one way bearing?
not as nice but here is another idea
I've been doing this for long time. I made a custom press for the swap :D
picture.php
Originally Posted by Racer 1966
Most likely those parts are ok. They are usually obvious if they are bad. A couple of things to check:
1 If you are using your press and just swapping the bearing in the sleeve, check that the sleeve is tight on the new bearing. This is a big problem when swapping that way
2. Check the starter shaft the bearing is riding on. Wear of only .001"can cause headaches.
3. The obvious have to ask question(same as Coby) Are you putting the bearing on the right direction?
yes the bearing is on the right way, i put calipars to the new bearing and old, turns out the stock bearing is NOT a (6x10x12) the internet lies the bearing actually measures (6.23x10.19x11.83) this is a major problem. so any body trying this be verry careful Now I have wraped up $50.00 just in a one way bearing by the time i go buy the $20.00 one from the hoby store
unless u have a suggestion on how i may be able it rigg the smaller ones i have, i thought about jb weld or something!!! any ideas i have 10 of them i would like to use
RACER!! this would have been good info to know a week ago
does anyone know a tutorial to replacing OWB? my pull start just started slipping for the first time. do i just take off the backplate and swap the hex thing?
