2.5r carb
vbgagnon
RCTalk VIP
Madawaska, ME
Revo Questions.....
The air inlet on the 2.5r carb is it the same size as a big block or is it small. Just wondering for airfliters/tube for my new rig...
pretty sure you need small block filters for that.....what I see some guys do is the SB elbow and use an intermediate tube for th efilter from a BB.....I really don't see the advantage in that though....the carb can only take in XX amount of air...putting th elarger filter doesn't give you any more air....
Small block. Motorsaver has a T-Maxx/Revo 2.5 filter, however the neck hits the spur gear in most applications. Just take the stock Revo neck, drill out the base of the motorsaver housing to 7/8" and stick the stock neck in there. That is if that's the route your looking to go.
NP, almost every airfilter I've seen other than the stock are MS's. Anyway, should give you an idea of where to start.
the small block MS don't have the same issue as the larger ones do...I like th elittle ones but the big ones suck the big one.....
