I'm having a heck of a time with my 2.5 tmaxx engine. It was running fine, about to start into my 2nd gallon of fuel. Now I can't get it to idle at all. I've tried with the idle screw all the way in, no luck. I can get it to run by turning the throttle trim all the way up but as soon as I hit the brakes it cuts off. I reset all the needles to the factory settings but it seems the only way to get it to run is hold it at 1/4 to 1/2 throttle. Could I have run it too lean causing premature piston/sleeve wear? An air leak in the system maybe? Any ideas would be much appreciated.
