. 18 wasp a peice of poop
MaxiMumST.2002
RCTalk Racer
welll i received my wasp in a couple 3 days ago and the stupid recoil already broke on it should i send it back? or what should i do?
it broke, what were u doing to it? what broke on it, the string, or the coil? weird that it broke.
later
i was only pulling not hard either the string came alll the way out and wont go back in i think the spring broke....What will i have to do ?
try sending it back, where did u get it? weird that a pull start coil broke on a brand new engine.
later
Have you taken it apart?
Maybe you just need to recoil the spring.
doesn't meant the whole engine is a piece of poop. Maybe the pullstart, but the engine???
I had the same thing happen on my picco/omega 21 I just bought. The pull starter is about the quality of dynamites on their mach .15... in other words it sucks.
On mine, the recoil spring came detached from it's connection point in the housing. It was easily remedied, but was annoying considering it only has about 15 tanks through it.
I would try to contact the manufacturer and explain your problem to them. They may just send you another pull start. In the meantime, you can take it off and see if it is easily repaired.
If not, send it to me...and I'll fix it and send it back. PM me for details.
