spark plug= Glow Plug
anyways
you say it doesn't sound like it wants to turn over?
the engine IS brand new? Correct?!
Pretty much any new nitro engine has a VERY tight pinch on the sleeve that the piston slides up and down in. This pinch wont wear out after the first pull.
how to start your engine easier?
loose'n your glow plug up a bit, fire it up, once its running. tighten the plug down. yes its frustrating. sometimes with brand new engines, as soon as you remove the glow igniter the engine will die, and this results in your glowplug leaking fuel and making a mess. No biggy! can always clean things up.
so go ahead and try loosening your glow plug up a bit, yank on the pullstart. Now remember, short fast pulls on that pullstart.
crank that engine over and keep your fingers crossed that it fires up.
