Duratrax Onyx 150 LiPo Charger
Duratrax has a new LiPo charger designed for the budget friendly modeler, the Duratrax Onyx 150. A built-in power supply makes it easy to take along. Once the Onyx 150 is plugged in, all the modeler needs to do is hook up a pack and set the charge rate. The Onyx 150 provides balanced charging for 1-3S LiPo packs. The Onyx 150 will start and stop automatically and also features a multi-color LED for reading charge status at a glance.
Onyx 150 LiPo Charger Features
  • Charges 1-3S LiPo packs to maximum voltage, and balances with +/- 5mV accuracy
  • Includes a compact switching power supply for AC/DC charging convenience
  • Perfect for packs with Deans Ultra Plug or Traxxas High-Voltage connectors
  • Offers switch-settable charge rates, sound cues for setup ease and a tri-color LED for status updates
  • Custom cc/cv charge profile ensures maximum voltage and prevents overcharging
  • Includes 90-minute safety timer and a built-in cooling fan
  • Protected with solid-state reverse polarity and current overload circuitry
  • Includes a balancing port for balancing and charging 3S packs, plus an adapter for 2S packs.
  • 5-year limited warranty.
  • Onyx 150 LiPo Charger Specifications:
    AC Input: 110V 60Hz
    DC Input: 11-15V
    Battery Type: 1-3 LiPo cells (3.7-11.1V) only
    Battery Capacity: 100-7500mAh
    Fast Charge Current: 1.5A, 3.0A & 5.0A (50W)
    Output Connections: attached leads w/Deans Ultra Plug connector, Traxxas adapter & universal radio jack (for 1-3S LiPo packs)
    Input Connections: attached AC lead and detachable DC lead w/alligator clips
    Case Size: 5.3 x 5.0 x 1.9 in (133 x 127 x 48 mm)
    Weight: 12.6 oz (356 g)
    Part #: DTXP4195 – Onyx 150 AC/DC Balancing LiPo Charger
    MSRP: $79.99
