Axial Bender Customs SWX Chassis Kit
Bender Custom SWX Chassis Kit
Check out the new Bender custom SWX chassis kit from Axial. The SWX chassis is the originator of the open sided motor plate and the narrow chassis is designed for squeezing through tight spaces with just the right amount of suspension travel the maintain stability.
A delrin skid plate wraps under the side plates to help your RC crawler slide over the rocks better. The same skid plate also has a directional channel down the center to help prevent lateral slides when on the rocks!
Bender Customs SWX Chassis Features
  • Counter sunk screws help prevent hang ups
  • Thick 3mm aluminum side plates provide a rigid chassis
  • Includes grey anodized links and bolts directly to any AX10 Scorpion
  • Complete easy to follow instructions makes it easy for anyone to install and setup
  • Allows the use of most transmissions and dig units currently on the market
Part #: AX30506 – Axial Bender Customs SWX Chassis Kit
MSRP: $120.00
Give us your thoughts about the Axial Bender Customs SWX Chassis Kit in our RC Rock Crawlers forum!
