XRAY presents the all-new 808E – the electric powered version of the successful XRAY nitro XB808. The XRAY 808E has been designed for professional racers andfeatures ultra-high performance parts, finest quality materials, unmatched precision in manufacturing, and backed up with legendary XRAY support and service. The 808E is a professional race car delivered in kit form to let you select and install your own electronics.
Balanced load distribution on the XRAY 808E buggy creates outstanding driving dynamics and excellent track stability, making the 808E super-easy to drive in any racing condition – no matter if you drive on flat fast track, bumpy technical track, or sky-high jumps! The 808E is the new form and level of performance.
The XRAY 808E is also loaded and equipped with premium high-tech materials and engineering throughout – excellent and proven suspension and geometry; oversized shocks; optimal and centralized weight balance; superior drivetrain concept – the 808E is easy to drive and control, making it a top performer under all racing conditions. Precision controllability at your disposal… response so fast and precise that you think your mind is directly connected to the car. Squeeze the throttle for the first time and you will immediately experience what the car’s looks only hint at.
XRAY 808E Specs
- premium high-competition off-road electric-powered buggy
- kit version only – for professional racers
- based on the ultra-successful 808 platform, shares majority of parts
- efficient Zero Kingpin suspension
- strong, lightweight molded steering blocks with molded-in steel bushings
- well-proven 808 suspension parts and geometry
- ultra-low CG, all parts centralized in chassis
- optimized front/rear and left/right weight balance for perfect jumping
- pure racing design, highest-performance ultra-durable parts
- ultra-lightweight high-tensile transmission parts hand-made from special world-renowned, top-secret, self-developed HUDY Spring Steel
- drivetrain includes 22 high-speed rubber-sealed bearings for maximum efficiency, speed, and durability
- ultra-precision front/rear and center diffs with HUDY Spring Steel outdrives
- pinions, spurs and crown gears manufactured by HUDY
- optimized multiple upper/lower shock mounting locations for front and rear
- exclusive adjustable turnbuckles from HUDY Spring Steel
- flexible suspension holders with integrated preset optimal suspension geometry
- high-tensile Swiss 7075 T6 hard-anodized chassis
- ultra-strong inboard & outboard suspension pivot pins
- direct Shaft Connection to the pinion gear
- front & rear anti-roll bars
- narrow servo saver and steering system
- front & rear flexible composite brace
- gearboxes with Labyrinth Dust Covers
- premium-grade graphite shock towers: 4mm extra-thick front & 3.5mm thick rear
- big-bore oversized shocks for excellent handling on bumpy tracks and big jumps
- threaded big-bore hard-anodized shock bodies
- protective folding rubber shock boots for big-bore shocks, front & rear
- ultra-low XRAY racing body
- XRAY Premium Shock Oils for perfect consistency
Part #: 350150 – XRAY 808E 1/8th electric buggy
