Team Losi LST2 Resources
Team Losi LST 2 Mods:
The Team Losi LST2 is the next generation of big block nitro horsepower and ingenious design, bringing you the most advanced monster truck ever conceived. Taking Team Losi's original “2005 Truck of the Year” Team Losi LST to the next level of performance, the Team Losi LST2 features a POWERFUL new Mach 427 engine, newly designed driveshafts and axles for added strength, 20mm anodized aluminum wheel hexes, bulletproof aluminum differential cases, 420-Series dish wheels and racing tires, beefed up suspension components and much more. Aluminum clutch shoes offer long life and strong, positive engagement to harness the power, directed through a revolutionary transmission that shifts on the fly while climbing rocky inclines or blasting the Team Losi LST2 across the flats at speeds over 40 MPH. And you will stay in precise control the entire time with JR's premium XS3 synthesized computer FM radio system. The Team Losi LST2 is the complete, high-performance, ready-to-run package that monster truck racers have been looking for.
Team Losi LST2 Features
- Potent new 7-port Mach 427 engine
- Newly-designed oversized driveshafts, bearings and axles for added strength
- Revised suspension arms, hubs, carriers and spindles
- 20mm anodized aluminum wheel hexes
- Mega shocks with threaded anodized bodies and adjuster nuts
- Team Losi Spin-Start Electric Starting System
- Exclusive Multi-speed transmission w/reverse and slipper clutch
- Sealed 2-speed spur gears
- Steel-geared vicous differentials
- Bulletproof aluminum F/R differential cases
- 420-series dish wheels
- Low-profile ATX racing tires
- Aluminum clutch shoes
- High-capacity fuel tank
- Dual-disk brakes
- Pro-tune linkage set
- 1100MAH Ni-MH receiver battery pack and 110V charger
- Premium JR XS3 Synthesized radio w/2 steering servos
- Dual metal-geared Z590 steering servos
Team Losi LST2 Specifications
- Type: 4WD Nitro Monster truck
- Scale: Monster Truck
- Width: 18.5 in (470mm)
- Wheelbase: 14.2 in (361mm)
- Weight: 13 lbs. (5897g)
- Chassis: Dual-deck aluminum with composite ladder braces
- Suspension: 4-wheel independent H-arm
- Drive Train: Center Hi/Lo trans, 2-speed w/slipper and 2 differentials
- Tire Type: ATX low-profile racing tires
- Motor or Engine: Mach 427 (.427cc) with tuned exhaust system
- Radio: JR XS3 Synthesized FM system
- Servos: Z590 (steering x 2), Z270 for throttle/brake & shift
- Batteries: 1100MAH NiMH receiver pack
- Charger: 110v, 100MAH overnight charger
- Speed: 40+MPH
- Wheel Size: 40-series using 20mm drive hex
- Kit/RTR: RTR
- Shock Type: Oversized threaded coil-over mega shock
- Body: LST2 Racer type, prefinished
- Ball Bearings: Complete
- Fuel Tank Capacity: 220 c.c.
Team Losi LST 2 Pictures
