Associated RC10T5M Team Kit Stadium Truck
RC10T5M team kit stadium truck
Team Associated has just released news of their latest R/C stadium truck, the RC10T5M Team Kit! Associated has taken the very successful design of the B5M buggy with it’s mid-motor configuration and did the same with the RC10T5M along with an aluminum chassis. This design allows the T5M to take advantage of surface conditions and high traction levels available on today’s stadium truck tracks.
Read moreAssociated RC10T5M Team Kit Stadium Truck
Associated ESS-One Engine Sound System and light kit
ESS-One Engine Sound System in SC10 29260
The new Team Associated ESS-One engine sound system and light kit will take your scale realism to a new level. The ESS-One engine sound system allows you to pick from a number of throaty race engine sounds as well as shifting, brakes, and turbo blowoff valve sounds. USB programmable allows you to each change your desired sounds. Great for short course truck, drift, or rally car, the ESS-One has the sound you’re looking for!
Read moreAssociated ESS-One Engine Sound System and light kit
Replay XD Prime X Camera
replay xd prime x camera
The new Replay XD Prime X camera has been completely re-imagined with not only it’s low profile, more than double the battery life (1700mAh battery, providing 3.5 hours on a single charge), along with it’s waterproof design up to 10 feet, but the Replay XD Prime X features a 145° wide angle T2.8 lens and cinema grade anti-glare coating. Record in 1080p up to 60 frame per second!
Read moreReplay XD Prime X Camera
Associated’s Stealth Transmission Kit for the RC10 Classic
Associated RC10 Classic stealth transmission
The legendary Stealth 3 gear transmission is back and as a kit to add performance to your RC10 Classic buggy. The new Stealth Transmission kit offers higher performance and better durability than ever before with the addition of the Factory Team V2 slipper clutch. Also included with the Stealth Transmission is a super smooth adjustable ball differential that helps manage the power in the corners.
Read moreAssociated’s Stealth Transmission Kit for the RC10 Classic
Associated RC10TC6.2 Factory Team Kit
Team Associated just announced their latest version of their ever popular TC6 touring car platform, the TC6.2 Factory Team. As expected the Associated TC6.2 Factory Team has a number of improvements and fixes making it even better than the previous version such as the upgraded bulkhead, chassis configuration and top plate that allow flex to be optimized by disconnecting the drivetrain bulkheads and suspension mounting systems. The RC10TC6.2 is only 88mm wide and 2.25mm thick, and the carbon fiber chassis remains very narrow, resulting in reduced drag during the hardest cornering.
Read moreAssociated RC10TC6.2 Factory Team Kit
