Serpent F180
Serpent F180 #300000
Serpent will be releasing the new F180 (#300000) in two versionsAvailable in 2 versions: a kit which you will build the F180 from the ground up. The Serpent F180 kit will include the body, tuned pipe, and tires. The only required parts that doesn't come included will be an engine (the Serpent F180 will accept .21 – .28 engines), radio gear, fuel and a starter.
The second version of the Serpent F180 will be a Ready to Race (RTR) version which will come factory assembled and include a Futaba radio, Mega FT-28 engine, as well as a starter system and pre-cut body and a larger Serpent F180 wheeled pit bag!
Serpent F180 Engine
Serpent F180 Specifications
  • 1/8 scale rear wheel drive
  • Realistic Formula F180 body-shell (pre-cut)
  • Adjustable rear nylon wing
  • 5mm CNC machined chassis-plate
  • Lay-down, push-rod type suspension front & rear
  • Independent front and rear suspension
  • Adjustable front anti-roll bar
  • Pre-assembled RCC shock-absorbers
  • Angled engine mount for lower C of G
  • Compact polished tuned pipe system
  • Ventilated disk-brakes front & rear
  • Rear gear-differential (pre-assembled)
  • Centax clutch system
  • 2-speed automatic gearbox
  • Rubber profiled F180 tyres with hard foam inserts
  • Pre-mounted tyres on F180 spoked wheels
Serpent F180 Performance
  • Acceleration: 0-60 mph in 3 seconds
  • Top-speed: 65 mph
Part #: 300000 – Kit Version
Part #: 300010 – RTR Version
MSRP: N/A
Release Date: March 2007
Discuss the Serpent F180 in our On-Road forum.
