RPM front and rear a-arms for the Losi Mini 8ight
Make your Losi Mini 8ight that much more bulletproof with RPM’s newest front and rear a-arms for the Losi mini 8ight! Each RPM Losi mini 8ight A-arm starts with a beveled 30° leading and trailing edges and beefed up shock and anti-sway bar mounts.
The outer hinge pin support diameters have been beefed up to almost double the thickness of the stock A-arms while a more modest increase in size has been designed into the inner hinge pin support diameters as well.
Each Losi Mini 8ight RPM front and rear A-arm is molded in black out of RPM’s extremely tough blend of nylons and are backed by RPM’s industry-leading warranty against breakage. If speed is your thing, you need RPM armor on your ride!
Part #: 73552 – Front A-arms for the Losi Mini 8ight – Black
Part #: 73722 – Rear A-arms for the Losi Mini 8ight – Black
MSRP: $9.95 /pair
